car dock
MarkR
Member
Has anyone found a good car dock with charging capabilities (Wireless would be great)?
I've gotten used to my car dock for my droid maxx and use it everyday for work. So I want to make sure I have the same for the DNA if I get one.
I haven't seen one. I am not sure the Qi standard works with 12V DC power yet, so it may be a while.
We just announced the HTC DNA today. See attached photo for details and below is the post we made it a couple of Forums...
The new HTC car-dock is now in production and here is a link to the page where it can be per-ordered. We guarantee 1st week of January but we are trying for two weeks from now... When the wireless charging dock comes (end of Q 1) we'll send a nice discount coupon to anyone that has purchased this one. After much internal discussions (and reading all comments in XDA and Android Central about car-docks) we decided to go with a microUSB steel enforced arm on the side instead of doing a vertical microUSB "slide on" solution. The reason is that we felt a strong customer demand to make this new Dock compatible with Otterbox Defender, Ballistic, Trident type cases, which is very challenging otherwise. the rest of the features are: (with comment)
1. Spring loaded latch. Users told us they don't want to insert the phone and have to "fold down" the latch. This makes is a smooth 1-step motion to insert the phone. The opening supports phones up to 92 mm (essentially a Note II with a thick case).
2. Expandable feet to fit phones up to 18 mm thick. Adding an Otterbox Defender to an HTC DNA makes it twice as thick!
3. 17 mm ball joint mount on the back of the Dock. Turn any direction with one hand. The Dock also works with any mounting solution compatible with Garmin, type a dashboard mount etc. For anyone preferring a ProClip vent mount or KUDA leather mount type solution you can just add an AMPS mounting adapter and they will play nicely together.
4. Automatically triggering car-mode. The microUSB arm starts the HTC driving app (see pictures) but on Google Play there's several good apps, including CarHome Ultra, that can be used as a replacement "default" car-home screen.
5. A 9ft (2.7meter) USB charging cord is also in the box. This makes it possible to place the Dock on the left side of the steering wheel, where it is out of the way and within easy reach. This position is also "legal" in California. The other end of the cable plugs in to the USB port on the car. If you don't have one in your car, plug into a 12 Volt car charger featuring a USB port (which most people probably already have?).
6. Open back so the Dock can function as a "dash cam" without any blockage. We're amazed how many people seems to use this feature.
7. Compact and pretty stylish size. Much smaller footprint then even a medium size HTC phone. Users like you guys have told us that when the phone is not in the Dock you don't want a big "blob" of plastic obstruction the view.
Well, that's it folks! Price is $44.95 but a $5 off coupon code is 5OFF2012 until end of December. Feel free to comment and we'll do our best to answer any questions or suggestions.
Just now did a preorder on Amazon. The link didn't work but I found it. $39.95 + $4.49 shipping (the promo code has expired). Ship by 1/7/2013.
Thanks
So did anyone buy the car dock listed above or any others? Need to buy one and was curious what others are using. Thanks
