Was anyone able to fit their X with a case on into the Motorola car dock? The dock comes in with a removable bracket inside, that makes the grip a little wider.
Stock X fits inside with the bracket in. So, I assume you remove the bracket to fit X without taking it out of the case. Unfortunately none of the cases that my local Verizon store had worked.
I have a gel case (got it for free, can't complain), and the phone won't fit into the cradle with it. Sales rep also tried hard case (two parts that lock together, and give you a rubberized feel on the outside), and it's no go either.
Which case did they make the cradle for? Unfortunately the manual does not mention anything specific.
Thanks.
Thanks.
