FirebirdStud
christmas? wow all droid x users will have a car dock by then!
Best of luck to you my friend!My advantage is that the case works in the dock, and is easy to open if you already own another dock, there are about 10-15 advantages my case has. Another competitive advantage in that I own this phone, they all own iphones!. Im sure most people agree that a case/car dock combo at 20 if its of great quality is a deal. Im trying to break into this very competitive maarket. This case has to be the best solution for the most people, that's what im all about.
You wouldn't have pics of how it turned out would you? Also the case you used. I think I know which case it is... I like the look.For the record, I have the SEIDEO MTDX Case (the thin one) and I was looking for a solution to the car dock issue when I stumbled on this forum...
I did exactly this.. I pulled the insert out of the Car Dock ... Took the heat gun and heated up the lower portion of the Car Dock.. Inserted my phone with the case on it, and it molded itself right into the dock! Had to do it 2 times with it to get a really good fit.
This method WORKED LIKE A CHARM!! Excellent idea. Looks stock, fits snug. Even with the insert back installed into the Car Dock you cannot tell. Took all of 10 mins.
So there ya have it folks. Get the SEIDEO Case and apply a little heat. wala!
FH
Why so many people are determined to cram their phone into the Motorola dock with a case on it doesn't make a whole lot of sense to me. But oh well, to each his/her own.
ok yeah someone did some work on their car dock. i kinda did it the easy way i guess. i just dremeled off the front lip instead of using a heat gun. it doesnt take very long but take your time and it will come out fine. took me about 2 minutes plus there was no painting or any other mods to do and now i can fit any case i want in my car dock. this is an older thread but if someone is still interested ill post some pics
No modification and here are some pictures
