Accessories Cases for A70 and A101
djvorac
I know that there are a few floating around out there so I figured I would start this off.
I have an A70 8GB. Personally I have no need for an actual hard/fitted case.
Instead I picked up a Netbook bag. This one. It will fit my A70, power cable, other cords, sd cards, screen cleaner, some beef jerky.... (yes, I just checked and I actually had beef jerky in there). It works for me anyway. Yes I know that this has become my man-purse but it's great for traveling and taking to work. It also doubled as a folf bag last week. It held 4 discs and a couple beers. :D
So, what have you all got?
I just got myself a 'golla' case. It's slightly too large, but I think it will do a good job of pretection. Price was not too bad either, (not much point in repeating the price right now, unless you use Moldovan Lei!)
Photo attached
I found these that while are not cheap should fit perfectly:
Amazon.com: Tuff-Luv Tri-Axis 'Veggie' Faux Leather Case Cover For Archos 101 Internet Tablet / Archos 10.1 / Arnova 10 - Black: Electronics
I got this which is a little loose but does the job:
Amazon.com: 10.2" Synthetic Leather Case with Keyboard and Stylus Pen for ePad and aPad (Black): Electronics
there is a bit of a problem with the usb cable dangling and being a bit too deep, but for the price it seemed the best option.
