monkeytools
All right here we go. This is a stock rom. First things. Flash this at your own risk.
OK I have tested the rom and it works. Again do this at your own risk. i will help if there is a problem. But with no hard button combo to get into recovery. there is a risk if it wont boot. that the phone will not be able to be recovered.
Yes you need custom recovery to flash this. Download zip put in a folder name folder what you want. Then put folder on you sdcard.
TO Flash
I recommend downloading Quick Boot from play store. so you can reboot to recovery.
Go to Backup/Restore then select Nand backup. Then check what you want to backup. I recommend checking everything.
make a full back up and save to your pc.
reboot back into recovery
Then go to wipe (this is a good idea so there is no conflicts with something you have down loaded) do a wiper all data/ factory reset.
Note before enter recovery. you can use titanium back up to save your stuff and reload after you reboot.
Then wipe cache and wipe dalvik-cache.
Go to Flash Zip menu.
Then Choose zip from sdcard.
Go to the file that you put your zip in.(mine is named stock casio)
Then select on Casio_stock_rom.zip
Then at the bottom it will ask. Install : casio stock rom/casio_stock_rom.zip ?
Press menu to confirm. press menu button and wait a until it has finished flashing. then reboot phone.
reboot will be longer than normal.
released for testing. rom file here Dev-Host - casio_stock_rom.zip - The Ultimate Free File Hosting / File Sharing Service
post results in forum. Again flash at your own risk. And hit the thanks button to my tester willster419 without him this may have not happened.
This can be used as a base rom for anyone to use. All i ask is you give me credit and a link to my rom. Lets get modding people.
TO Flash
