Root [CDMA] Am i rooted???
I unlcoked the htc - says unlocked in fastboot mode.
however i doownloed root checker. It says i'm not ROOTED?!
also i bought 4ext and says it needs to install busybox! busybox won't install because it says i'm not rooted. HBOOT 1.5 is installed and s-on is on. HELP!:mad:
HOW DO I INSTALL BUSYBOX??? OR GIVE IT SUPERUSER PRIVLEGES. SO FRUSTRATE
You need to flash a ROM to give it Su privilege check the rooting for noobs sticky at top
so i installed mean room on s-on with hboot 1.5.
mean rom ketp rebooting after install. so i flashed - "AnthraX-htcleak-rls1.zip" with 4ext.
that fixed it! i'm good go go!
