Root [CDMA] boot manager lite issue
zevas
i used this application on my evo 3d, and guess what, i booted a rom in which i couldnt get gapps on to it, thus unable to log into my gmail. in turn i did a recovery and it still booted into the other rom. so i erased the boot manager file. Well now my htc evo 3d wont boot into anything. it just stays on the green and white htc screen. so what now?
Pull battery. Resart into bootloader (hold volume down + power button). Then select recovery. Then use the wipe menu to wipe data, wipe cache, wipe dalvik cache. Optionally but suggested format all partitions (except sd card). Then try to restore your backup again in the recovery menu.
Just some info for you, you should always wipe data and cache and dalvik cache before flashing anything to avoid problems such as boot loops etc.
pull battery. Resart into bootloader (hold volume down + power button). Then select recovery. Then use the wipe menu to wipe data, wipe cache, wipe dalvik cache. Optionally but suggested format all partitions (except sd card). Then try to restore your backup again in the recovery menu.
i also had the same problem...i tried what u told but nothing working !!
Do you think this could possibly be an s-on issue? For example 4ext recovery app gives you the option to choose s-on and will allow you to flash roms that you otherwise couldn't..?
Edit: Oops I didn't realize what program they were talking about. I am using boot manager and have only flashed the stock rom as my alternate. It didn't give me any trouble. I am also s-off.
