scotty85
Extreme Android User
this lets you change all the firmware,so everything matches,if you need to swap between hboot 1.50 and 1.58 hboots.
requirments:
*be s-off. these are pulled from RUUs,and are not signed files.
*be cdma. these will brick a gsm phone
*have an md5 sum checker,and use it
these filescontain hboots and radios,and can brick your phone if you get a bad or incomplete download.
hboot 1.50:
PG86IMG-1.50-hboot-firmware.zip
md5: PG86IMG-1.50-hboot-firmware.zip b7174debc61dda20b4c3f9b51ba2c790
hboot 1.58:
PG86IMG-1.58-hboot-firmware.zip
md5: PG86IMG-1.58-hboot-firmware.zip 512dd47f3470de41032d6ba5981b3edc
again,please double check md5s prior to flashing.
disclaimer: i do not have a cdma 3d to test these so,flash at your own risk. if you test and they work,please report and ill change this to reported working
requirments:
these filescontain hboots and radios,and can brick your phone if you get a bad or incomplete download.hboot 1.50:
hboot 1.58:
