I know this may be a stupid noob question, but I will ask it anyway and maybe it will help others later. I have looked all over the forums and other to try and find the answer but had no luck finding a clear answer. So here is the question:
What are the proper steps to flashing a rom that doesn't work with the current hboot on the device?
I know the phone must be s-off and you would have to wipe everything. The stuff you have to do for all flashes, and you would have to flash the correct hboot for that rom. But what order does it need to be done in?
Flash the PG86IMG file in the bootloader before installing the rom?
or
Install the rom then boot into the bootloader and flash the PG86IMG file?
or
Does it matter which order it is done in?
If this information could keep others and myself from really screwing up their devices, it would greatly help. Thank you in advance for you time and answers.
or
or
