Root [CDMA] How I achieved MMS on CM nightly 20140615
Zenwafer
First I took a look at CM's apns-conf.xml in Notepad+.
Then I found & edited the apn 'Boost Mobile CdmaNai' (as that is the one that applies to my device) to read as follows
I then amended CM's build prop with 4 lines
When I rebooted all was well with MMS & carrier label :cool:
Very impressive. I am wondering if you should report this to the developer of CM?
Don't know if anybody else has been following, but the thread over at XDA got a little out of hand today. dhacker abandoning the project because everyone whines and no one contributes.
He's come back saying there will be updates, but after some time off.
I am sure others would find this useful as well.
Didn't see that over on xda yet. That's a shame if he really does give up
Anyways, I flashed Seraph's PA, let it update to RC2 and all I did was add 1 line in the build prop -
ro.cdma.home.operator.numeric=311870
No need to edit apns-conf on that one as the info in it will work but we still need to specify which one to use
Yes, the moderators have been jumping in all day to well, moderate.
Is that line the only thing I need to change on Seraph's new? I'm still a little new at this.
Edit: Would mind sharing a screenshot of exactly where it needs to be edited?
Just add it at the end
That screener is from CM, but you should get the idea.
Excellent.
If anyone else tries this fix please report back your success or failure & which ROM you're running
whoa!? it fixed the data issue on crom 7.1?? have you tested?
I'll give it a test run prov some time tomorrow out the next.. will report back afterwards..
Yeah please let us know i hope to get mine turned back on in a week or so.
Edit: @DeathToFlesh I am able to get through to voice mail now on crom 7.1
dope! yo I've never edited build.prop or any XML files before.. what app do I need for editing?
going to charge my phone then give it a shot, if not tonight then tomorrow for sure..
Here I made it a little easier for people. I had to put the files in zip to upload. This is not an installer it just the files you need to replace in stead of editing it yourself. Just unzip and replace files then reboot.
apns-conf.xml goes in /system/etc
build.prop goes in /system
Here is the ZIP
Here is the ZIP
I used the above zip file on C-rom 7 data is working but no mms., any ideas?thanks.
I have data and mms working in the messaging app now on cm11 nightly 6-26. Thanks to all who helped out :)
I am putting together a flashable in hopes to unify this fix for all the different builds out there. I already have the cm11 part finished and it is working, but I need a couple things if anyone has time.
1. I need a pastebin of the default /system/etc/apns-conf.xml for all the builds to see if the Boost line that needs editing is the same. If it is I am already finished, but I doubt it lol
2. @Tattooedgod did you get stock VVM.apk working or just the ability to call voicemail to check messages? If you have VVM.apk working with proper notifications, please provide details on how to achieve this so i can add it to the flashable.
Thanks in advance for the assistance ;)
Most ROMs based on cm use there apns-conf.xml nope I don't use visual voice. I couldn't even call be for I did this
Well that is unfortunate, because I find the 9016 text messages rather annoying lol
Here is the flashable that makes the changes to build.prop and apns-conf.xml. It edits the files rather than swapping them out so as long as the Boost line is the same it should work for all the variants.
falcon_Boost_Service.zip
edit: If the Boost line is not the same, it won't do anything so there is no worry about it breaking something
edit2: Link removed. A newer version can be found HERE
Here is the ZIP
We got data on c-rom 7.1!!
We just don't have MMS
Not even working on hangouts.
EDIT: My assumption is that MMS doesn't work because c-rom isn't a cm base build anymore?
