It appears aamikam finally got around to working on the e3d again. It's going to hard to top what viperboy has put out but I always loved mik's roms.
Giving it a try in a few.
http://forum.xda-developers.com/showthread.php?t=1416830
Ok guys, I finally made it to the Evo3D...
This rom is based off of HTC Runnymede 1.05.401.4 and the Pyramid 2.08.401.1 with Sense 3.5 and GB 2.3.5.
This is the initial release and there will be future updates as needed.
A really big thanks goes out to Cappychimp and RC-Team for a lot of the added tweaks and multidevice zip, to romanbb for the original tweaks, and to team Warm for a lot of the work in porting runny to the Evo3D.
This ROM supports GSM and CDMA Evo3D devices thanks to team Warm that got the differences sorted out which made my work on making it work on both devices close to nothing.
Features:
Ext 4 (cgoodman kernel #5[/URL])
OC
Odex (DeOdex might come later if u guys will ask for it, other wise... its not worth it)
Fully Optimized and tweaked
Zipalign on boot
Defrag DB's on boot
Busybox 1.19.3
Native screen capture
Beats audio, Dolby, SRS, and EQ in music player
HTC Quicklaunch widget from bliss also added
Unlocked more settings in Browser
Rosie, Notifications, Lockscreen and StatusBar tweaks changes "on the fly"
Longpress Volume keys to skip tracks when screen is off mod added (Longpress Vol up is next, and Vol down is Back)
Htc Amaze Camera with 3d Video/Images fully working
All Gapps and market apps updated to newest versions
All other stock sense 3.5 goodies included
Known Bugs:
4G don't work (probably never gonna happen)
Effects in album FC (aligning 3d images still works) - Fix is HERE[/URL] (thanks to Will972)
Sprint Vvm is giving issues (will be fix soon, for now u guys can use googlevoice, or anything else)
Tweaks:
These tweaks are a lot like RCTweaks as they are based on their work... but there are more than a few extras that me and chingy added in.
- Settings Tweaks
Statusbar Options
Clock Options
- Style (show/hide/center)
- AM/PM Style (show/small/hide)
- Color
- Hide alarm icon
Battery Options
- Battery bar (like Miui with settings thanks to pvy)
- Show/Hide
- Color
Signal Options
- Show/Hide
- Text
- Color
- Transparency
Notification Menu Options
- Recent apps show/hide
- Date show/hide
- Transparent BG
- Skins (Stock/Inverted)
- Default to quicksettings
- Customize quicksettings (show/hide)
Rosie Options
- Custom button
- Hide navbar label
- Quick scroll (3d/2d/semi)
- Drawer matrix (4x4/4x5/5x4/5x5)
- Transparent BG
- Depagineted app drawer
- Bliss Rosie
Display Options
- Overscroll settings (none/glow/bounce & glow/bounce)
- Window and Transition animations speeds (6 diff speeds + off)
- CRT on/off
- Unlock animation on/off
- 3D home
- Font Sizes (7 different sizes)
- Auto brightness settings
- Softkeys lights (on/off/always on)
Misc Options
- Lockscreen (Honeycomb/Android/HTC - all on the fly)
- SD crad read ahead speeds (128kb - 4096kb | set to 2048 by default)
- Volume key screen on
- SMS screen on
- Snapshot (enable/disable)
- Volume key to take a picture
- HTC_IME Arrow KB (on/off)
- Beats Boost
Phone Information
- Radio etc.
- Battery
- Usage stats
- Wifi
- System Tweaks
Boot options
- Reboot
- Hot Restart
- Recovery
- Bootloader
- Power off
GodMode
Mount system RW
Mount system RO
Debloater & Storage space
- Remove system apps (use at your own risk as there is no restore option yet)
- Internal & External Storage summery
Memory settings
- Default
- Free up 50/70 MB
Maintenance
- Clear Dalvik-Cache
- Clear Cache
- Fix Permissions
Enable/Disable commands
- Camera sound (on/off)
- Vibration (default/med/low)
- Ads (hide/show)
Bootanimation
- Disable
- Enable
- Get rid of
- Extras for fun
Download Center
- Htc hub widgets/skins/apps (make sure to d/l ones for your sense version)
Sounds
- Bootanimations sounds
- Volume rocker sounds
- Screen lock sounds
Themes
- Bootanimations (make sure to d/l ones for your device resolution)
- Shutdown animations (make sure to d/l ones for your device resolution)
- Fonts (many to choose from...)
