Uploaded new version. Audio is fixed again
Just a quick question. Which gapps file do i flash?
Is the in call volume supposed to be fixed in this build? I still can't adjust the volume in call. Should I factory reset and get a fresh install?
What I did for cm9 was make a titanium backup of the voicemail app in midnight rom. I restored it after I flashed cm9 and it worked perfectly. I'd try that.
Do you think it will ever be possible to get the camera working/3D? I know the phone is of its own breed being a 3D camera so the drivers wouldnt be readily available...
I'm facing this issue with my Touchpad as well. I just cant get lucky can I...
A reply from jmz? Please
I am sure camera will be working eventually. I would not count on 3D cam(at least not for sometime). I would say 3D is very low on the priority list. At this point I would say mms and cam should be at the top of the priority list for most people to call this a daily driver. As with anything android, it will just take time to get it working properly. JMZ may disagree with me, but that is how I see it at this point.
Thanks for the tip. Did you do anything special, or just restore the app?
I restored it, but it's saying I have voicemails that cannot be downloaded.
And just to confirm, the icon is yellow and blue, right? Wondering if I have Sprint voicemail on my phone and not VM voicemail.
I've noticed some issues with apps such as Apollo and the browser force closing also wifi doesn't want to turn on, that issue might be fixed haven't checked on the newest version though
Sounds about right, mms and cam should be next. this rom would rock if it had that. lol.
Actually FCing? Or just closing? Did you flash a diff kernel? Which build you on?
Force closing process has stopped etc, anthrax, and the current one 9/12
I need to note it on first post. Anthrax kernel will no longer properly function on this ROM. This was due to alignment with cm standards in ultimate goal of getting official support going
Does the Sprint EVO 3D have official CM9?
Crap. Any alternative kernel that will work that works on 1.04 hboot?
