Root [CDMA/SHOOTER][ROM] Unofficial CM9 for Shooter Beta
Status
Not open for further replies.
Pushed through downloading (by pausing and resuming about 10 times) Installed rom. itll get past HTC Logo, and itll move into spinning blue CM9 for about a min or two, then it reboots and does a bootloop after getting to the CM9 spinning logo, any idea what I did wrong? Used Jeunobear to get s-off
I am seeing something that may help MMS. Reflashing now to test. Also you have some Sprint in the build.prop still. Other than that I ran it all night with no issues and wimax works great.
Edit: My MMS theory was a no go. Still looking into it.
Yeah I already took care of that. But it wasn't the cause of mms failing. Specifically mms is looking for sprint apn. And sprint apn doesn't exist anywhere in rom. I confirmed this by both grepping and running strings on the rom. I used my known working mms from one v and it still doesn't work. But like I said I have a guy that knows a lot about VM mms and he will be looking at it this afternoon.
I copied everything I did for the one v to this for virgin mobile. But 4 hours isn't enough time for me to explore everything.
As I said before this was a semi rushed build. So it is highly possible I missed some thing easy. I will have fresh eyes later
SD was fixed yesterday after I released that build. Camera will also be included on next build also
Take your time jmz. Rome wasn't built in a day and no one here should expect a perfect build of CM9 right now. I support you and all you do.
I appreciate your hard work and will patiently wait until you are ready to release a full build. Until then, everyone needs to be patient and just reports bugs.
Thank you again jmz!
Sounds like you Didn't downgrade your H Boot. You must be running eng 1.04 Or the ROM will not be able to boot
Yeah I was under the impression Juenobear did it for me, but I followed another post in here to do it, and It booted up. Thanks :) :smokingsomb:
I already tried to make a patch a few weeks ago which included the one v pure VM apn..bp changes...but my testers said a big fat no go
I can confirm that Sixaxis is not working through both Bluetooth and with my little setup.
https://www.box.com/s/4ef7c21574dfeddb83bf
https://www.box.com/files#/files/0/f/0/1/f_2935455753
Was just reading on Xda, in Mac's kernel thread, and I guess it must be broke, he said, xda-developers - View Single Post - [Kernel][AOSP] MAC Kernel - 0.8.5 [OC | Sweep2Wake | Smartass v2 | Noop] Also, not sure if it needs to be turned on, on the rom side, JMZ would have to answer that.
I know that you probably already have this, but here is a logcat of sending a MMS with the changes I have made. It appears to be looking at the right APN but still failing.
Code:
--------- beginning of /dev/log/system
I/ActivityManager(  242): START {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10200000 cmp=com.cyanogenmod.trebuchet/.Launcher} from pid 242
I/ActivityManager(  242): START {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.android.mms/.ui.ConversationList bnds=[321,864][424,960]} from pid 442
W/InputManagerService(  242): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@411ffa90 (uid=10025 pid=1402)
--------- beginning of /dev/log/main
D/MMS Input Type( 1402): 64
D/OpenGLRenderer(  442): Flushing caches (mode 0)
D/OpenGLRenderer(  442): Flushing caches (mode 1)
D/dalvikvm(  242): GC_CONCURRENT freed 2080K, 50% free 6196K/12288K, paused 2ms+6ms
D/dalvikvm( 1402): GC_FOR_ALLOC freed 2296K, 80% free 5783K/28867K, paused 28ms
I/dalvikvm-heap( 1402): Grow heap (frag case) to 26.758MB for 12582928-byte allocation
D/dalvikvm( 1402): GC_CONCURRENT freed 54K, 38% free 18016K/28867K, paused 2ms+3ms
D/dalvikvm( 1402): GC_CONCURRENT freed 16707K, 78% free 6492K/28867K, paused 2ms+4ms
D/dalvikvm(  242): GC_EXPLICIT freed 226K, 50% free 6152K/12288K, paused 2ms+4ms
D/dalvikvm( 1402): GC_EXPLICIT freed 1975K, 81% free 5765K/28867K, paused 2ms+4ms
V/TransactionSettings( 1402): APN setting: MMSC: http://mmsc.vmobl.com:8088/mms? looked for: null
D/ConnectivityService(  242): startUsingNetworkFeature reconnecting to 0: enableMMS
D/ConnectivityService(  242): ConnectivityChange for mobile_mms: CONNECTED/CONNECTED
D/NetworkPolicy(  242): applying policy NetworkPolicy[NetworkTemplate: matchRule=MOBILE_ALL, subscriberId=valid]: cycleDay=22, warningBytes=2147483648, limitBytes=-1, lastSnooze=-1 to ifaces [rmnet0, rmnet0]
D/dalvikvm(  432): GC_EXPLICIT freed 1027K, 58% free 5249K/12288K, paused 1ms+4ms
D/Tethering(  242): MasterInitialState.processMessage what=3
I/MediaUploader(  933): No need to wake up
D/PicasaSyncManager(  949): active network: NetworkInfo: type: mobile[CDMA - EvDo rev. A], state: CONNECTED/CONNECTED, reason: 2GVoiceCallEnded, extra: , roaming: false, failover: false, isAvailable: true
D/PicasaSyncManager(  949): background data: true
D/TelephonyProvider(  432): Preferred APN: -1
D/dalvikvm( 1402): GC_CONCURRENT freed 1272K, 79% free 6335K/28867K, paused 3ms+7ms
D/dalvikvm( 1402): GC_CONCURRENT freed 1781K, 78% free 6397K/28867K, paused 10ms+5ms
D/Mms     ( 1402): [174] markAsRead: update read/seen for thread uri: content://mms-sms/conversations/8
D/ConnectivityService(  242): handleInetConditionHoldEnd: net=0, condition=100, published condition=100
D/OpenGLRenderer( 1402): Flushing caches (mode 1)
W/IInputConnectionWrapper( 1402): showStatusIcon on inactive InputConnection
D/OpenGLRenderer( 1402): Flushing caches (mode 0)
D/dalvikvm( 1402): GC_CONCURRENT freed 1795K, 78% free 6431K/28867K, paused 4ms+4ms
D/dalvikvm(  442): GC_CONCURRENT freed 3550K, 72% free 4009K/14083K, paused 4ms+5ms
I/ActivityManager(  242): START {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10000000 pkg=org.jtb.alogcat cmp=org.jtb.alogcat/.LogActivity bnds=[12,123][141,305]} from pid 442
D/dalvikvm( 1465): GC_CONCURRENT freed 3657K, 59% free 5121K/12288K, paused 6ms+5ms
D/dalvikvm( 1465): GC_CONCURRENT freed 738K, 50% free 6164K/12288K, paused 2ms+2ms
I/BATT_ALG(  142): charging time: 0
I/BATT_ALG(  142): batt_alg_overtemp_check:temp:310, isOver_temp:0
I/BATT_ALG(  142): set_battery_voltage_alarm level=98, alarm_config=25, batt_alarm_config=25
I/BATT_ALG(  142): vol=4331;curr=177;dis_curr=0;temp=310;id=2;level=98;chg_src=1;chg_en=1;isOver_temp=0;timer=60;safety_count=0
E/Mms:transaction( 1402): Url: http://mmsc.vmobl.com:8088/mms?
E/Mms:transaction( 1402): Connect to /205.239.233.136:81 timed out
E/SendTransaction( 1402): java.io.IOException: Connect to /205.239.233.136:81 timed out
E/SendTransaction( 1402): 	at com.android.mms.transaction.HttpUtils.handleHttpConnectionException(HttpUtils.java:296)
E/SendTransaction( 1402): 	at com.android.mms.transaction.HttpUtils.httpConnection(HttpUtils.java:282)
E/SendTransaction( 1402): 	at com.android.mms.transaction.Transaction.sendPdu(Transaction.java:176)
E/SendTransaction( 1402): 	at com.android.mms.transaction.Transaction.sendPdu(Transaction.java:154)
E/SendTransaction( 1402): 	at com.android.mms.transaction.SendTransaction.run(SendTransaction.java:115)
E/SendTransaction( 1402): 	at java.lang.Thread.run(Thread.java:856)
E/SendTransaction( 1402): Caused by: org.apache.http.conn.ConnectTimeoutException: Connect to /205.239.233.136:81 timed out
E/SendTransaction( 1402): 	at org.apache.http.conn.scheme.PlainSocketFactory.connectSocket(PlainSocketFactory.java:121)
E/SendTransaction( 1402): 	at org.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:144)
E/SendTransaction( 1402): 	at org.apache.http.impl.conn.AbstractPoolEntry.open(AbstractPoolEntry.java:164)
E/SendTransaction( 1402): 	at org.apache.http.impl.conn.AbstractPooledConnAdapter.open(AbstractPooledConnAdapter.java:119)
E/SendTransaction( 1402): 	at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:360)
E/SendTransaction( 1402): 	at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:555)
E/SendTransaction( 1402): 	at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:509)
E/SendTransaction( 1402): 	at android.net.http.AndroidHttpClient.execute(AndroidHttpClient.java:262)
E/SendTransaction( 1402): 	at com.android.mms.transaction.HttpUtils.httpConnection(HttpUtils.java:202)
E/SendTransaction( 1402): 	... 4 more
E/SendTransaction( 1402): Delivery failed.
D/ConnectivityService(  242): stopUsingNetworkFeature: teardown net 0: enableMMS
D/ConnectivityService(  242): ConnectivityChange for mobile_mms: DISCONNECTED/DISCONNECTED
D/NetworkPolicy(  242): applying policy NetworkPolicy[NetworkTemplate: matchRule=MOBILE_ALL, subscriberId=valid]: cycleDay=22, warningBytes=2147483648, limitBytes=-1, lastSnooze=-1 to ifaces [rmnet0]
D/WimaxService(  242): onReceive ConnectivityService CONNECTIVITY_ACTION type=mobile_mms[CDMA - EvDo rev. A], state=DISCONNECTED
I/BATT_ALG(  142): batt_alg_overtemp_check:temp:312, isOver_temp:0
I/BATT_ALG(  142): vol=4312;curr=51;dis_curr=0;temp=312;id=2;level=98;chg_src=1;chg_en=1;isOver_temp=0;timer=60;safety_count=0
D/dalvikvm( 1465): GC_CONCURRENT freed 1590K, 49% free 6315K/12288K, paused 2ms+2ms
W/InputManagerService(  242): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@413d8cd0
D/dalvikvm( 1465): GC_FOR_ALLOC freed 1943K, 51% free 6078K/12288K, paused 13ms
D/dalvikvm( 1465): GC_CONCURRENT freed 1512K, 48% free 6394K/12288K, paused 3ms+2ms
W/InputManagerService(  242): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@410ff7c0
D/dalvikvm( 1465): GC_CONCURRENT freed 2218K, 52% free 5999K/12288K, paused 1ms+3ms
D/dalvikvm(  242): GC_CONCURRENT freed 1648K, 49% free 6287K/12288K, paused 2ms+16ms
D/dalvikvm( 1402): GC_CONCURRENT freed 1395K, 77% free 6807K/28867K, paused 3ms+3ms
Code:
what changes did you make to get it to look at the right apn?
Can we not use these apn settings in the apns.xml file in the framework-res.apk? Just asking.
only sense roms use that. In AOSP its in apns-conf.xml in system/etc
If you look at cm framework-res the apns.xml in framework-res.apk is blank
Oh ok.. Thanks for the lesson jmz. You da man!
Edit: Just curious... I see there is a proxy and port in the apns-conf.xml and not on the sense rom apns.xml. Could that cause a problem?
Please bear with me, I'm trying to learn myself.
Here you go. This is receiving and download MMS.
Code:
I/ActivityManager(  243): START {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.android.mms/.ui.ConversationList bnds=[321,864][424,960]} from pid 439
D/MP-Decision(  630): UP Nw:2.700000 Tw:180 rq:5.000000 seq:195
D/OpenGLRenderer(  439): Flushing caches (mode 1)
D/dalvikvm(  243): GC_CONCURRENT freed 1696K, 54% free 5667K/12288K, paused 4ms+5ms
I/ActivityManager(  243): Displayed com.android.mms/.ui.ConversationList: +240ms
D/OpenGLRenderer(  439): Flushing caches (mode 0)
D/dalvikvm(  243): GC_EXPLICIT freed 47K, 46% free 6665K/12288K, paused 2ms+6ms
D/MP-Decision(  630): DOWN Ns:2.100000 Ts:270 rq:2.000000 seq:298 (Up time:395)
I/BATT_ALG(  142): batt_alg_overtemp_check:temp:346, isOver_temp:0
I/BATT_ALG(  142): set_battery_voltage_alarm level=99, alarm_config=25, batt_alarm_config=25
I/BATT_ALG(  142): vol=4313;curr=87;dis_curr=0;temp=346;id=2;level=99;chg_src=1;chg_en=1;isOver_temp=0;timer=60;safety_count=0
D/WAP PUSH(  517): wpman processMsg 4:application/vnd.wap.mms-message
W/WAP PUSH(  517): no receiver app found for 4:application/vnd.wap.mms-message
D/MP-Decision(  630): UP Nw:2.700000 Tw:180 rq:3.300000 seq:196
D/dalvikvm(  752): GC_EXPLICIT freed 138K, 55% free 5611K/12288K, paused 5ms+19ms
W/CursorWrapperInner(  752): Cursor finalized without prior close()
D/MmsSmsProvider(  425): getSingleAddressId: insert new canonical_address for xxxxxx, _id=4
D/MmsSmsProvider(  425): getThreadId: create new thread_id for recipients xxxxxxxx
D/MmsSmsProvider(  425): insertThread: created new thread_id 5 for recipientIds xxxxxxx
W/Mms/cache(  752): RecipientId 4 not in cache!
D/dalvikvm(  425): GC_EXPLICIT freed 945K, 78% free 2753K/12288K, paused 3ms+3ms
V/TransactionSettings(  752): APN setting: MMSC: http://mmsc.vmobl.com:8088/mms? looked for: null
D/ConnectivityService(  243): startUsingNetworkFeature reconnecting to 0: enableMMS
D/ConnectivityService(  243): ConnectivityChange for mobile_mms: CONNECTED/CONNECTED
D/NetworkPolicy(  243): applying policy NetworkPolicy[NetworkTemplate: matchRule=MOBILE_ALL, subscriberId=valid]: cycleDay=22, warningBytes=2147483648, limitBytes=-1, lastSnooze=-1 to ifaces [rmnet0, rmnet0]
D/MP-Decision(  630): DOWN Ns:2.100000 Ts:270 rq:0.000000 seq:297 (Up time:590)
D/MP-Decision(  630): UP Nw:2.700000 Tw:180 rq:6.000000 seq:208
D/MP-Decision(  630): DOWN Ns:2.100000 Ts:270 rq:0.000000 seq:297 (Up time:388)
D/Tethering(  243): MasterInitialState.processMessage what=3
D/MP-Decision(  630): UP Nw:2.700000 Tw:180 rq:7.100000 seq:195
D/TelephonyProvider(  425): Preferred APN: -1
I/MediaUploader(  976): No need to wake up
D/MP-Decision(  630): DOWN Ns:2.100000 Ts:270 rq:0.000000 seq:318 (Up time:413)
D/ConnectivityService(  243): handleInetConditionHoldEnd: net=0, condition=100, published condition=100
I/ActivityManager(  243): START {dat=content://mms-sms/conversations/5 cmp=com.android.mms/.ui.ComposeMessageActivity} from pid 752
D/Mms/compose(  752): [1] [initialize] savedInstanceState = null intent = Intent { dat=content://mms-sms/conversations/5 cmp=com.android.mms/.ui.ComposeMessageActivity } mConversation = [+1 913-549-8889] (tid 5)
D/MMS Input Type(  752): 64
D/Mms     (  752): [125] markAsRead: update read/seen for thread uri: content://mms-sms/conversations/5
I/ActivityManager(  243): Displayed com.android.mms/.ui.ComposeMessageActivity: +202ms
D/OpenGLRenderer(  752): Flushing caches (mode 0)
D/MP-Decision(  630): UP Nw:2.700000 Tw:180 rq:3.800000 seq:198
D/dalvikvm(  752): GC_EXPLICIT freed 670K, 53% free 5864K/12288K, paused 10ms+6ms
D/MP-Decision(  630): DOWN Ns:2.100000 Ts:270 rq:0.000000 seq:317 (Up time:711)
W/InputManagerService(  243): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@41115658 (uid=10025 pid=752)
D/OpenGLRenderer(  752): Flushing caches (mode 1)
D/dalvikvm(  752): GC_EXPLICIT freed 314K, 55% free 5618K/12288K, paused 3ms+3ms
I/ActivityManager(  243): START {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10000000 pkg=org.jtb.alogcat cmp=org.jtb.alogcat/.LogActivity bnds=[141,123][270,305]} from pid 439
D/dalvikvm(  243): GC_CONCURRENT freed 2755K, 54% free 5688K/12288K, paused 3ms+7ms
D/MP-Decision(  630): UP Nw:2.700000 Tw:180 rq:6.400000 seq:198
D/dalvikvm( 1368): GC_CONCURRENT freed 4847K, 60% free 5248K/12803K, paused 2ms+20ms
I/ActivityManager(  243): Displayed org.jtb.alogcat/.LogActivity: +278ms
D/MP-Decision(  630): DOWN Ns:2.100000 Ts:270 rq:0.500000 seq:307 (Up time:395)
D/dalvikvm( 1368): GC_CONCURRENT freed 1082K, 54% free 5989K/12803K, paused 1ms+3ms
D/dalvikvm( 1368): GC_CONCURRENT freed 1463K, 51% free 6276K/12803K, paused 1ms+2ms
D/dalvikvm( 1368): GC_CONCURRENT freed 1665K, 51% free 6354K/12803K, paused 2ms+3ms
D/dalvikvm( 1368): GC_CONCURRENT freed 1925K, 52% free 6207K/12803K, paused 2ms+2ms
D/dalvikvm( 1368): GC_CONCURRENT freed 1709K, 51% free 6282K/12803K, paused 2ms+3ms
D/dalvikvm( 1368): GC_CONCURRENT freed 1712K, 51% free 6359K/12803K, paused 2ms+1ms
D/dalvikvm( 1368): GC_CONCURRENT freed 1886K, 52% free 6208K/12803K, paused 2ms+3ms
D/dalvikvm( 1368): GC_CONCURRENT freed 1676K, 51% free 6321K/12803K, paused 1ms+2ms
D/dalvikvm( 1368): GC_CONCURRENT freed 1808K, 52% free 6244K/12803K, paused 2ms+3ms
D/dalvikvm( 1368): GC_CONCURRENT freed 1642K, 51% free 6366K/12803K, paused 2ms+2ms
D/dalvikvm( 1368): GC_CONCURRENT freed 1872K, 51% free 6323K/12803K, paused 1ms+2ms
I/BATT_ALG(  142): batt_alg_overtemp_check:temp:347, isOver_temp:0
I/BATT_ALG(  142): vol=4302;curr=53;dis_curr=0;temp=347;id=2;level=99;chg_src=1;chg_en=1;isOver_temp=0;timer=60;safety_count=0
D/dalvikvm( 1368): GC_FOR_ALLOC freed 1740K, 51% free 6287K/12803K, paused 25ms
D/dalvikvm( 1368): GC_CONCURRENT freed 1750K, 51% free 6322K/12803K, paused 2ms+2ms
E/Mms:transaction(  752): Url: http://mmsc.vmobl.com:8088/ammsc/?A3dk_FNnctQP9YDfj
E/Mms:transaction(  752): Connect to /205.239.233.136:81 timed out
D/MP-Decision(  630): UP Nw:2.700000 Tw:180 rq:2.900000 seq:198
D/MP-Decision(  630): DOWN Ns:2.100000 Ts:270 rq:1.100000 seq:285 (Up time:285)
D/dalvikvm( 1368): GC_CONCURRENT freed 1824K, 51% free 6291K/12803K, paused 5ms+3ms
D/dalvikvm( 1368): GC_CONCURRENT freed 1824K, 52% free 6248K/12803K, paused 1ms+7ms
D/dalvikvm( 1368): GC_CONCURRENT freed 1714K, 52% free 6250K/12803K, paused 2ms+2ms
D/dalvikvm( 1368): GC_CONCURRENT freed 1631K, 50% free 6403K/12803K, paused 2ms+2ms
I/ActivityManager(  243): START {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10200000 cmp=com.cyanogenmod.trebuchet/.Launcher} from pid 243
W/InputManagerService(  243): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@41100700 (uid=10063 pid=1368)
D/dalvikvm(  243): GC_CONCURRENT freed 1811K, 54% free 5675K/12288K, paused 4ms+8ms
D/MP-Decision(  630): UP Nw:2.700000 Tw:180 rq:3.100000 seq:199
D/MP-Decision(  630): Error(-22) changing core status to online
I/ActivityManager(  243): Displayed com.android.mms/.ui.ConversationList: +168ms
D/dalvikvm(  243): GC_EXPLICIT freed 67K, 46% free 6653K/12288K, paused 2ms+7ms
D/dalvikvm(  425): GC_EXPLICIT freed 537K, 78% free 2767K/12288K, paused 2ms+4ms
D/MP-Decision(  630): DOWN Ns:2.100000 Ts:270 rq:1.366972 seq:308 (Up time:503)
I/ActivityManager(  243): Displayed com.android.mms/.ui.ComposeMessageActivity: +234ms
D/dalvikvm(  752): GC_EXPLICIT freed 312K, 52% free 5916K/12288K, paused 3ms+7ms
D/MP-Decision(  630): UP Nw:2.700000 Tw:180 rq:3.600000 seq:217
D/MP-Decision(  630): DOWN Ns:2.100000 Ts:270 rq:1.000000 seq:304 (Up time:304)
D/dalvikvm(  752): GC_EXPLICIT freed 249K, 54% free 5774K/12288K, paused 2ms+4ms
D/MP-Decision(  630): UP Nw:2.700000 Tw:180 rq:4.600000 seq:197
I/ActivityManager(  243): Displayed com.android.mms/.ui.ConversationList: +262ms
D/MP-Decision(  630): DOWN Ns:2.100000 Ts:270 rq:0.200000 seq:297 (Up time:378)
D/dalvikvm(  752): GC_EXPLICIT freed 125K, 53% free 5882K/12288K, paused 2ms+3ms
I/BATT_ALG(  142): batt_alg_overtemp_check:temp:349, isOver_temp:0
I/BATT_ALG(  142): vol=4300;curr=43;dis_curr=0;temp=349;id=2;level=99;chg_src=1;chg_en=1;isOver_temp=0;timer=60;safety_count=0
D/MP-Decision(  630): UP Nw:2.700000 Tw:180 rq:5.700000 seq:198
D/MP-Decision(  630): DOWN Ns:2.100000 Ts:270 rq:1.600000 seq:311 (Up time:311)
D/dalvikvm( 1368): GC_CONCURRENT freed 2678K, 57% free 5519K/12803K, paused 3ms+5ms
D/dalvikvm( 1368): GC_FOR_ALLOC freed 916K, 51% free 6295K/12803K, paused 16ms
E/Mms:transaction(  752): Url: http://mmsc.vmobl.com:8088/mms?
E/NotificationTransaction(  752): java.io.IOException: Connect to /205.239.233.136:81 timed out
E/NotificationTransaction(  752): 	at com.android.mms.transaction.HttpUtils.handleHttpConnectionException(HttpUtils.java:296)
E/NotificationTransaction(  752): 	at com.android.mms.transaction.HttpUtils.httpConnection(HttpUtils.java:282)
E/NotificationTransaction(  752): 	at com.android.mms.transaction.Transaction.sendPdu(Transaction.java:176)
E/NotificationTransaction(  752): 	at com.android.mms.transaction.Transaction.sendPdu(Transaction.java:123)
E/NotificationTransaction(  752): 	at com.android.mms.transaction.NotificationTransaction.sendNotifyRespInd(NotificationTransaction.java:242)
E/NotificationTransaction(  752): 	at com.android.mms.transaction.NotificationTransaction.run(NotificationTransaction.java:210)
E/NotificationTransaction(  752): 	at java.lang.Thread.run(Thread.java:856)
E/NotificationTransaction(  752): Caused by: org.apache.http.conn.ConnectTimeoutException: Connect to /205.239.233.136:81 timed out
E/NotificationTransaction(  752): 	at org.apache.http.conn.scheme.PlainSocketFactory.connectSocket(PlainSocketFactory.java:121)
E/NotificationTransaction(  752): 	at org.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:144)
E/NotificationTransaction(  752): 	at org.apache.http.impl.conn.AbstractPoolEntry.open(AbstractPoolEntry.java:164)
E/NotificationTransaction(  752): 	at org.apache.http.impl.conn.AbstractPooledConnAdapter.open(AbstractPooledConnAdapter.java:119)
E/NotificationTransaction(  752): 	at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:360)
E/NotificationTransaction(  752): 	at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:555)
E/NotificationTransaction(  752): 	at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:509)
E/NotificationTransaction(  752): 	at android.net.http.AndroidHttpClient.execute(AndroidHttpClient.java:262)
E/NotificationTransaction(  752): 	at com.android.mms.transaction.HttpUtils.httpConnection(HttpUtils.java:202)
E/NotificationTransaction(  752): 	... 5 more
E/NotificationTransaction(  752): NotificationTransaction failed.
D/ConnectivityService(  243): stopUsingNetworkFeature: teardown net 0: enableMMS
D/ConnectivityService(  243): ConnectivityChange for mobile_mms: DISCONNECTED/DISCONNECTED
D/NetworkPolicy(  243): applying policy NetworkPolicy[NetworkTemplate: matchRule=MOBILE_ALL, subscriberId=valid]: cycleDay=22, warningBytes=2147483648, limitBytes=-1, lastSnooze=-1 to ifaces [rmnet0]
D/dalvikvm( 1368): GC_CONCURRENT freed 1692K, 51% free 6351K/12803K, paused 1ms+2ms
D/WimaxService(  243): onReceive ConnectivityService CONNECTIVITY_ACTION type=mobile_mms[CDMA - EvDo rev. A], state=DISCONNECTED
D/MP-Decision(  630): UP Nw:2.700000 Tw:180 rq:4.700000 seq:198
D/MP-Decision(  630): DOWN Ns:2.100000 Ts:270 rq:0.700000 seq:315 (Up time:315)
D/dalvikvm( 1368): GC_CONCURRENT freed 1714K, 50% free 6431K/12803K, paused 2ms+2ms
D/dalvikvm( 1368): GC_CONCURRENT freed 1949K, 51% free 6317K/12803K, paused 1ms+2ms
D/dalvikvm( 1368): GC_CONCURRENT freed 1564K, 49% free 6578K/12803K, paused 1ms+2ms
D/dalvikvm( 1368): GC_CONCURRENT freed 1940K, 51% free 6392K/12803K, paused 2ms+2ms
Status
