Root [CDMA] Sprint voicemail notification
devov
Member
I am running Mean Rom and I keep getting these voicemail notifications popups. Is anyone else getting these? Its only done it on one other rom besides this one. I like this rom so I don't want to change. Advice please.:D
I've never used vvm myself, there isn't an option inside the app to disable notifications like most apps?
DS[/Quote
I think I should mention that I am flashed to Verizon so I don't think its an app thing. Its a notice for having a voicemail message but I can't read it until I go activate on Sprint. Weird huh?
I'm going to try something like what you suggested.....I think I'll uninstall the factory app and download one off of Playstore.
DS
No, at least not on version T.5.3.0.30, and on MEAN, there's no tweaks, unless he flashed them separate (my wife's on Mean)
I have used Google Voice since it was launched...
just for VM though..not total integration...that is a mess...
Never thought about using it for that! I'm with you on the full integration thing. It's crazy. Thanks for the idea!
I tried the Google VM app and I don't get notification but its trying to recognize my phone on Sprint although I'm on Verizon and says it can't verify my number with my google account. ( off subject, I see you are an Alabama fan.....I know someone who is making a custom carved Alabama electric guitar)
Hey, if you've flashed cross carriers, and the only issue you've had is with VM notifications, color yourself fortunate! I've heard of folks not quite so successful with such... OT - It'd be cool to see the guitar, but Roll Tide none the less! (with all due respect to DS and other SEC fans :D)
Yep same here, but be careful of the latest release in the app store, I had to revert back to an older version to listen to my Vmails, for some reason version .72 does not download the message, I sent a ticket in and others are having the same issue and some are not, so not sure where the problem lies, but older version working fine ;)
If GV does not work for you try Youmail, that is another app I use a while back that was good also, cheers.
Yeah, I love Verizon PrePay and so far thats my only issue. Trying a few other apps to see if I can get it going well. The thing about a Verizon flash is that it has to be done a specific way or you will get a lot of problems...finding the right flasher is the key, I tried 3 people before I found a "specialist". By the way, I'll try to remember to send you pics of the guitar when he gets done...its going to be real nasty.:D ( probably 4 to 6 weeks )
