cant seem to find widget lock on app brain.
only lockbot
Random question regarding Widgetlocker....if you have the sense slide down lock screen...can you change it to a left-to-right slider instead?
How is Widgetlocker when it comes to lagging?
I have used an app that changed the lock screen before and it was horribly laggy, so bad that i gave up and went back to the stock.
No lag here... And I have a widget on my lock screen that was always stuttering/laggy on my samsung moment.
My only issue with widgetlocker atm is that it seems to have messed with the sense weather animation. No amount of touching or interacting with the screen will make the animation go away. It doesn't effect performance or interaction in any way, but I have to tolerate the animation for 2-3secs until it finishes itself.
All paid apps on the Android Market have a 24hr money-back return policy. So download it when you have time to mess with it. I downloaded it, played around with it, then found a couple problems and returned it and notified the developer.I may give it a try then, I really liked the Eclair lock screen so i could silence the phone quick with out going into it. I'm running LP Plus, and dont use the weather animation so i'm gold there. It would be great if they had a lite version so i could give it a try before purchasing.
I'm thinking about getting WidgetLocker. But, not sure what I would put on the lock screen that would be useful.
What widgets/apps do you guys use on the lock screen?
I use these, except now I use Smooth Calendar widget (it's MUCH better, it looks just like the HTC 4x1 calendar widget) instead of that orange/black whiteboard thing above the slider.I'm thinking about getting WidgetLocker. But, not sure what I would put on the lock screen that would be useful.
Then a day later I found out that the main problem was being caused by another app. So I fixed that app and downloaded widgetlocker again, and the next day they updated it to close a security problem I had found.
So... yeah. You can return it, and also take comfort that the developer is very responsive.
You have to be rooted to post pictures?
