emerica243
Im on a eris running xtrROM 4.x and want to change the lockscreen to the new droid x slide version. I searched and seen something about gridlock but am confused.
Thanks, got it!
You were able to flash it on Xtra???
So am i, i guess you should "learn to live with the stock htc one" heh.
Hook your phone up to your computer, open up ADB.exe in a command prompt, do ADB DEVICES, and it should show your phone. Now switch to usb mode, throw the file on root of the sd card, switch back to charge only. Now power off the phone, boot into recovery, flash the zip. When its done, in the command prompt do this.
adb remount
adb shell
cd /system/app
mv HtcLockScreen.apk HtcLockScreen.bak
Reboot phone, and thats it.
exit
adb remount
adb shell
cd /system/app
exit
