Root Change Text Color?????
AndroidAdmire
Is there anyway to change the Text Color??? Like popup menus or buttons that say "Yes" or "no" in the dialog box.
Thanks!
-AndroidAdmire
You can change any colors you want.
The fun part is finding where those colors reside for certain things within the UI.
This type of stuff is found by going in and putting in the long long hours and work and rebooting the phone 100+ times till you get it right.
Within each of the "theme apk's" colors can only be changed in a couple of spots. One of the xml's is even labeled "colors".
The other places are where you would make changes to the different UI parts such as length, width, padding, etc.... Colors can also be changed in there.
Trial and error is all I can say.
Good luck.
