How do I change the color of the calendar labels? For example i wantto make the gmail label red and my exchange labels blue. is this posible?...where would i do it?
I believe this has to be done from gmail>calendars on gmail.com. If you sync your outlook to gmail you should have no problem changing the color. I have 5 calendars synced to gmail all with different color labels
