Ok, now that I'm all into this root thing, one more question.
How do I change fonts to different size and style?
rom toolbox has a font option.. not sure if it works on sense though...
I'm Midnight senseless, and I tried it. Nothing changes. I've used it to try to change the boot animation, the font and the battery icon to a different color. Nothing is changing after rebooting.
"you cannot paste here because the file system is a read only" is the message I get when I tried to move it.
I noticed that the mount was set to r/w, and I changed it to r/o.
But after I got the screen pop up like you said, and did those checks, I got this: "Permissions change was not successful. Please note that some file systems (e.g SD card) do not allow permissions changes".
You mean renamimg it and leaving it in its original folder?
okay... at least we have that... now what are the permissions of the bootanimation.zip... they should beOk, I got what you meant, and got it to move into the right folder without changing the permissions. I renamed it bootanimation.zip, but when I rebooted the phone, the same one played.
first line...nothing
second line....all 3 boxes checked
third line....1st,3rd boxes checked
Still same animation.
I'm wondering if I should move the one thats playing to some other folder, say the root toolbox, where the one I want to play came from.
