Help Changing In-Call volume has no effect
rwarwood
Hi,
Since upgrading to ICS on my Galaxy S2, changing the in-call volume has no effect.
Pressing the side rocker button will show a volume slider moving up and down on screen (which will never go to zero), but it has absolutely no effect on the volume of the person I am speaking to. I am aware I can use Audio Manager to change the default call volume outside the call, but if I need to change the volume mid call (depending on the situation, obviously) I can't!
Has anyone else had this problem and if so any ideas how to fix it?
Android Version: 4.0.3
Baseband: I9100XXLPS
Kernel: 3.0.15-I9100XWLP7-CL340913 dpi@DELL123 #3
Build number: IML74K.XWLP7
Thanks!
Hi,
Thanks!
Hi,,,
Mee tooo having the same problem.. did u solve it.?
Come on folks. Nobody has an answer to why this is happening? The S2 may be a few years old but its still a very common phone that carriers still sell new. I can't believe that nobody cares enough to find a solution to this.
It's difficult to find a solution if you're not experiencing the problem.
A quick Google search didn't turn up any other threads reporting the same issue. It could be a software problem, in which case a factory reset might fix it.
