Root Changing partition tables
grentuu
Member
After almost a year of being S-ON i took the rather simple plunge with the revolutionary method and after a pain less 5 minutes my desire is now S-off. the reason I did this was because more and more roms are using non stock tables. My question is, is there a thread somewhere that can explain the differences and how to install them?
you can either manually flash the above hboots with fastboot
or you can use custom mtd
what recovery are you on?
