I changed mine a while back. It has changed back to Sprint. Im running an SOS ROM and the ##775# wont work to get me back in to change it. Any other ways to get back in there? Im using a non-sense version of that ROM.
it was fine but i think i did an update by accident while running SOS. i noticed this morning that my battery was at 50% at 9 am. it was still on charge at 8 am. Sprint sucks around here. they tell me its network upgrades.... i was afraid id have to flash back and forth.... i just did a Ti back-up assuming i would have to do this. was hoping for a quick fixer
oh, well..... i have 4-5 ROMS on my sd card just in case..... lol!
I've never had to do this but is it the EPST.apk that allows for the use of these codes??
Couldn't you extract the apk from a ROM which has the fully working one (MikG, I think Karma's ROMs has it), and move it over to the system of the ROM you're currently using with a File Manager?
I just based my reply from what I've read many times. Its plausible I suppose? You would know more about that than I would
I'm not really sure.I just based my reply from what I've read many times. Its plausible I suppose? You would know more about that than I would
Hey Mike! Yeah, you need to nand backup your current rom setup, flash back, or nandroid back to a sense rom like MikG to use the ##775# code, change prl, then back to SOS...
I've found that on a sense rom, your prl can automatically change without notice....I changed my prl while on MikG, flash Decks and it has not changed.
My boss, on MikG, changed his prl, and occasionally it will auto update....gotta look into that yet for him![]()
I don't believe that the prl will auto-update, it has to updated manually![]()
perhaps that's the issue?I think in his settings somewhere he has it set to "cdma-auto prl" or something like thatperhaps that's the issue?
