the files you are looking for are the "dial_num" files in Contacts.apk
you can find dialers online that u can swap in http://forum.xda-developers.com/showthread.php?t=1013757
or create ur own using a program like paint.net
The phone.apk has a dialer in it as well. Contacts.apk's dialer is for when you're geting ready to make a call, and the phone.apk's dialer is when you're in a call and have to press a number (lie when you call a bank's automated system). One word of warning, though: you may receive errors while decompiling or recompiling the phone.apk, or it may not work right when installed to the phone. I tried theming a phone.apk to match my red theme, and when I flashed it with CWM, the app force-closed on me any time I tried to make a call, and the phone wouldn't connect to 3G.
yeah i forgot to make the changes in Phone.apk when i made my dialers. I beleive u can use the same dialer images from contacts.apk (with same names) for phone.apk.
U dont need to decompile in order to change images in phone apk or images apk. i use zipthemer to overwrite the images, or u can use ninjamorph (both free in market)
I havent tried but u may be able to use 7zip (open archive, not extract) to drag and drop images into the apk
Could be that the apk I was using was messed up from the get-go, or I accidentally dragged something over like an xml file, but tried that, and when my phone booted up, it wouldn't connect to 3G, and phone.apk kept FCing.
