This guide is intended for people who are on CTMod or CM7 and http://androidforums.com/galaxy-prevail-all-things-root/496242-script-dm-cm7-ctmod-update-2-10-a.html doesn't work for you. So, let's get started.
1. MAKE A BACKUP!!! I can't stress this enough.
2. Follow the instructions at this link: http://androidforums.com/galaxy-prevail-all-things-root/375550-odin-return-phone-stock-factory-updated-02-23-new-fa19-image.html. MAKE SURE TO CHOOSE A ROOTED IMAGE WITH CWM SO YOU CAN RESTORE YOUR PHONE
3. Once on stock, go to this link: http://androidforums.com/galaxy-prevail-all-things-root/460182-1984kbps-speedtest-net-results-after-couple-tweaks.html. Follow the instructions in the section titled "Switch to a Sprint PRL"
4. Turn off your device and start it in recovery mode by holding volume up and power til you get to CWM recovery.
5. Install your ROM's zip file by going to "Install zip from sd card > Choose zip from sdcard > [insert name of your zip file]"
6. Restore from your backup.
These are the steps I took in changing my PRL. You my choose to back your sd card up to your computer but you shouldn't need to. I had no issues with files on my SD card. Ultimately the only difference from before you start to after you're done is your PRL version. Your backup will restore all your apps and phone settings to the way they were before you started.
Hope this helps everyone!!
