HowStuffWorks "Cell Phone Codes" im thinking that the sid if changed would provide better signal possibly has anyone else looked into this
Can you change it in root explorer and my channel is 575 yours is just 75i tried changing the sid but it didnt work. i know theres a file in in stock roms where you can change the channel. its called persist.sys.channel. it is located in /data/property/ mines set to 75. i had my phone connected to cdma workshop and i had it on monitor and the channel changed as the signal strength changed. you could also try doing to the NAM tab, select nam1, read, change where it says system to standart, and then write it is by default set to home only. i seem to get a better signal.
No the nam1 to system can that be changed in root explorer
I have never took notice if mine changes when I travel I will look next time I think were on to something here tho oh well time to get my lucky charms
