The only thing the Charge has over the Bionic would be the screen and possibly the camera. Performance wise the bionic should kill the charge unless there are major flaws with it. We already know the screen will probably suck on the Bionic and who knows about the camera.
i really like the camera feature that samsung has put on the charge i use to have a samsung epic and the cam was great just like the charge.
Droid Charge has a gyroscope and accelerometer like the iphoneso i got my charge 4 days ago from Verizon, i have seen videos on the droid bionic and i dont know if its me but when i look at the screen quality the colors are not the same, also i think it moves slow being a dual core is it just me ? can someone give me any opinion
any idea when this Verizon's Dual core SAmsung galaxy phone will be out?forget the bionic ill just wait for verizon to come out with a dual galaxy s phone like the charge, ......
so bring on Bionic ill wait for the verizon dual core samsung galaxy.
If you root your Charge and add the right elements, there is no reason to switch over to a Bionic. If you don't have a Charge and are deciding between the two, it will come down to the screen I guess. If you aren't going to root, then getting a Bionic would make sense.
I have my Charge rooted, Voodoo Lagfix, GummyCharged FE 2.0 and EP1Q (soon to be EP1W) modems. This thing flies! I tried the Bionic in a Verizon store and my Charge keeps up with it. There is no reason for me to change phones just for similar performance and a crappier screen.
I will hold out for the Prime and if it's a beefed up Charge, I will maybe go for that.
I compared exact web sites my charge vs. guy's bionic and my AMOLED screen made his look black / whiteso i got my charge 4 days ago from Verizon, i have seen videos on the droid bionic and i dont know if its me but when i look at the screen quality the colors are not the same, also i think it moves slow being a dual core is it just me ? can someone give me any opinion
I'd go for the Bionic in any circumstance UNLESS it has the same horrendous issues that the Charge does with regards to data and phone connections.
The specs of the Bionic are far superior, it will come pre-loaded with GB, and every Motorola phone I've owned in the past is tough as nails. (had a crazy ex throw one through a wall, literally, picked it up and it didnt even have a scratch on it)
