That's fine, I just wanted to find out if you were keeping the same battery between phones.
Mine will charge also if its left turned on....is this how its supposed to be? I have never owned a phone that you had to leave it on to charge it. Does anyone who owns this phone have any success turning it off and it charges successfully?
really? I didn't turn mine on until it was fully charged first time. works fine though.During the initial charge/discharge process, you're not supposed to turn the phone off at all.
I live in the US so Im not sure where mine was manufactured. All I know is if I turn off the phone and then charge it the light shows orange but when I wake up in the morning it is still showing orange and it is at the same level as when I first bought it. The only time it worked with the phone turned off was during the initial charge of the phone. I really don't know if I should take this back again or not!!
how do you mean, whats problem does that cause? I turn mine off regularly when I have no use for it.That should be fine, but turning it on and off again isn't recommended.
Now you have me really confused El Presidente. Why would I turn a brand new phone on first before the initial charge? When I asked you for the proper steps you didnt say to turn it on during the initial charge? Why will it charge with it turned on and it doesnt when its powered off? Just doesnt make any sense!!
I did the alternate instructions that you mentioned and I still can not chrge this phone while it is powered off. I just don't get it El Presidente!!![]()
well it does sound as though its a hardware fault somewhere. If you've returned all your phones to the same retailer you would think that they would try to find a solution to the problem, I cant believe you're the only one .... take it back and ask?
HTC said its not normal? Wow they are good!!! LOL...Its good to know Im not the only one....what store did you purchase yours from and is it a Virgin Mobile phone? Did the store give you a hard time?
but if i turn off ma phone and plugged to charger its indicating orange color all the night and next day too after that i switch on ma phone next day it was showing battery full but still the indicator is in orange color i was tired with this wildfire why its happening ? battery is good i can use for one day but ma problem is i want to turn off ma phone to recharge
that's impossible i cannot turn off ma phone ..... please help me with this
