Help Charging issue
ma phone charger is ok i checked with another charger same situation.... why is that happening is that any factory fault ? are they any possible to make it correct ? is this batch fail?
The same issue happens with me while I found out that during charging the phone through a wall charger, my phone tends to heat up. Now since I used to charge overnight with the phone beside me so the phone slips below the pillow at times.. making it heated up.
When the phone gets heated up then at a particular degree the phone stops charging. I believe its a preventive action pre-built inside the phone. In the morning I always find the orange light instead of a green light. I had to restart the phone to find my battery fully charged.
How I know my battery is fully charged? .. well I use the app 2x Battery.
Ever since I have started to charge my phone in a cool place the charge intake in perfect and it even shows the green light.
I hope this helps.
