Help Charging issues
mt htc evo 4g doesn't charge while its but charges while powered off. HELP!!!!!
My gf had this same problem with her 4g. Are you using the standard HTC charger that came with your phone or a cheap charger? Charging it from the wall or USB port?
i tried 4 different chargers. and i charged it from both.
Are you using the standard HTC charger though? If so try pulling the battery 5 - 10 minutes. If its still doing it only thing I could think is your charging port may be starting to go bad
