Root ChevyNo1 - Ssx 1.1 ROM
v4npro
First off - Merry Christmas!
Secondly - there are no screenshots yet, nor an unthemed version. It is Xmas so I won't be on long. That stuff will follow. This is based off 2.3.340 (/system). Hence the larger download size. Testing thus far has indicated that you MUST upgrade to 2.3.320 at a minimum. Plus all market apps refreshed.
Thirdly - I have only had two testers, no issues yet. One thing is clear though, again, you must upgrade to minimum 2.3.320 via OTA or SBF.
Not much else is new since I've been so busy. However, wanted to get a fresh update out
http://chevyno1.richstevenson.com/dx...1.1-update.zip
Another Mirror: SimplyStunningX-v1.1-update.zip
Merry Christmas Everyone! SSX 1.1 is Under the Tree ;) - Droid Forum - Verizon Droid & the Motorola Droid Forum
Note:(clockworkmod recovery glitch)
If while installing Ssx 1.1 you get an error message while installing asking your to force close or wait, select wait, then hit the power button and reboot. You'll be fine. It's a glitch with ClockworkMod Recovery.
Running it now... its a great BLUR ROM... I like it because using his Chevytools you can take out the Blur you don't want easily. I overclock using jrummy's tools instead of chevy's and its still fast. This might just be the ticket I've been waiting for.
well well well.....I will of course wait to hear how this goes for you guys..but I wouldn't mind trying this
Benchmark with pictures :D
Blue theme is built into the rom its a "simply stunning" thing from the original droid. I will give you a benchmark soon... I will say, its running great and I like being able to select what blur I do and don't want using his Chevytools.
Chevytools force closes on me when I try to open the scripts. Nandroid back to apex. My quad scores were around 1700 on chevyno1ssx apex around 1800 not much difference really
i have to agree ....no problems so far ....love that i have the option to add/remove stuff ,hopefully soon we will be able to change themes although i do like the blue i just like that option
Have to say, far from stock and in a few mins you can dump all the bloat with Chevy Tools.
Could also get it rid of it all with root explorer but whats the point when there are plenty of other ROMs that are exactly the same minus the bloat.
only problem i have so far is I'm getting double messages in Handcent
fixed, renamed messaging.apk and mms.apk to .bak
I was coming from FlyX with 928 Black Glass. Downloaded SSx and installed from SD...got stuck at M. Did battery pull and got the same results. Reverted to an old back-up I made when I was still on the stock OTA, tried again and it worked fine.
Start up seems slower, but seems really snappy otherwise. I use LPP instead of the ADW he included. Battery life will be watched today to compare to the old set-up. I'm using JRummy's OC app (not the one Chevy included in SSx) and at 1.25 (LV), it seems stable and netted me mid-1600 Quadrant scores.
The only issue I'm having is the stock "Messaging" app no longer works. I check my Exchange, Yahoo and Bellsouth emails there and it simply doesn't work. Click on an account and it immediately goes back to the home screen. I hope he gets a fix going for that and I'd be even happier than I am now with it.
The point is that some people like the bloat/BLUR. My ROM can appeal to both crowds. If you liked BLUR, would you be able to choose a blurless ROM? Nope - however, you have a choice with my ROM. I don't like taking out things unless EVERYONE agrees it is useless.
