inssane
Android Expert
Someone else had posted some findings between two different kernels and battery power, I can't find the thread - it's late though.
Anyhow - the Bekit kernel was recommended as being the ONLY type to use with BB V1, upon initial release. Battery sucked, we all know it.
Then I tried SetCPU, and a ton of different configurations - still sucked.
I have JuiceDefender and some like it, others don't - I happen to like it and always have.
The one thing I noticed initially upon the Bekit/V1 release was that the JuiceDefender widget:
(I grabbed this off google, it's the one on the left)
...was showing a constant 1.15x whereas my battery multiplier previously was a constant 1.95x. This widget simply confirmed that my battery life was sucking bad.
Went to the P3 1200LV and my widget made it to 2.15x and I noticed big time. Today I got 13 hours of light/moderate useage (internet, calls, text, email - NO wifi or GPS) and 13 hours got me down to 25%.
With the Bekit I was getting roughly 8 hours or so. Dropping 10% an hour on sleep.
I also want to add that I tried Chevy's 1200LV and it rebooted my system randomly.
The temp on Bekit and P3 are both good though. The Bekit would spike fast and drop, and so far the P3 is pretty stable and constant at 120 under good load.
Lastly - for those that don't understand the JuiceDefender widget, it is a multiplier. JD turns off APN for 15 minutes and then opens it for 2 minutes to save battery. The 2.15x means that I am getting 2.15 times the battery power as I would without toggling APN every 15 minutes - you get the point.
Well, that's my review. Marked, good increase in the first test day. No reboots, no major heating issues, etc. I used SetCPU and kept everything else constant with my testing, so this is a nice comparison.
Peace
Nick
Peace
Nick
