Root Clear Performance Difference - Bekit 1200LV vs P3 1200LV with BB V1
UPDATE: It seems that JuiceDefender doesn't work on CDMA phones with Android 2.1 - Motorola Droid and HTC Eris users, please be patient as I try to find a workaround, if possible - won't be easy, as I'm in EU.
Maybe some of it does. Literally my battery lasts twice as long. I've never been able to go 24hrs w/o charging let alone have 30% battery left.
I've used the bekit and the P3 both @ 1100. The bekit will run all day (9+ hours) under heavy use and never be lower than 30% at the end of the day. With the P3 I had less than 5% under the same use.
Funny thing is that I know I am not crazy with the JD thing, because the widget even showed me what I was noticing in battery increase and decrease.
I went from Cyan's latest test, which had a major hiccup in that slliding the keyboard out unlocked the phone and pocket dialed...so I went to NexBeast, and I lasted 19hours and had 30 percent left with pretty light use.
PROBLEM is that I "think" it was the P3, but it could have been the Bekit, lol, since I was trying both again.
I will have to nandroid back and see.
Nick
Why is it that with certain Droids, like yours, JuiceDefender works.. and with mine, it doesnt really. I mean I understand that it isn't suppose to work with Droid but.. yeah Im just wondering.. Hmm..
My multiplier says 2.07 right now, where it may not be that good, I notice a difference.
IDK
After flashing bb v1.1 I thought I'd give the bekit another chance. It always seems to be excellent for 2_3 days and then the battery takes a number 2 on me.
So.. I guess it starts to work on Droid after you leave it on for a while.
but my multiplier fluctuates between x1.99 and x2.10.. and i have noticed my battery lasting longer.. good stuff. =]
Just my $0.02:
I've been running CM (latest update, currently 5.0.7.1) and recently decided to go with a new kernel that showed up over on the CM forums:
jdlfg kernels - CyanogenMod Forum
jdlfg's kernel -- I'm running the 5 slot 1200mhz kernel -- has netted me the best battery life so far.
I know the OP is talking about BB, but at least on CM I'm getting at least a entire day out of my battery -- 16 - 20 hours with light-medium usage (though I admittedly don't listen to music on my phone).
My phone did not like that at all. Boot loop and now fc's!
Just my $0.02:
I'm curious as to why you guys believe that JD is working based on what the JD widget tells you ... seems like believing that Congress is working well based on a report from Congress, if you know what I mean.
Has any one got any objective data (hopefully measured same activities over the same time period with and w/out JD) that confirms a benefit on our Droids running 2.1?
As I mentioned before, I don't take complete stock in what the multiplier says.
I think it's optimistic, but it is concurrent to battery sucking kernels I have used. It's hard for me to get very good back to back comparisons, on and off JD, but I have tested a bit when I first tried it out and there is an improvement.
When I started using it, my phone was sucking up to 10% an hour just on idle and with JD I did notice that life got better, no exact numbers, but I would judge about 6-7% an hour instead, on the conservative side of the numbers.
With battery sucking kernels I have seen 1.2x-1.6x and on the current (Bekit) kernel, which is rocking about 5% battery reduction every 2 hours or so on idle, it shows 2.0x - So what the widget says and what I notice by looking at uptime and usage coincide.
It's late - I hope that made sense.
Not the most scientific, but yeah
