Root clock color
1iwilly
does anybody know where/directory file. you modified to change the color on the clock that is in the upper right corner of the status bar.????
ok after i wrote this. i found my answer by taking a chance, and trying this method.=OK HERE is an update. as to changing the color of the clock back to white. i took the service jar file from the sense rom=the one in the system/framework directory. copy it over the original one rebooted got my white clock back.
Should I just report this to a mod to just delete this thread? You wont be in trouble...just trying to help keep the forum clean :) :cool:
Personally I would rather still see the original thread/question... along with the answer or someone pointing to where the answer is if in fact the answer has to do with a rom.
You never know when someone else might have the same question. A searc h might lead them to this thread, and then to the rom/solution... Ya feel me?
No big deal but that is just how I look at it.
2 ways this can go: Restore the posts/questions for future members use or simply leave as is and this thread will die and sink to obscurity on its own.
Up to you guys
Thanks
Up to you guys
Thanks
thanks you can restore it. i wrote as to others have ask the same question. but there was no answers. this was for the titan rom.i tried it and it work for me.
or better yet lets just say that the service.jar is the file that has the color for the clock on the upper right corner of the status bar.
