Everything below assumes you have already rooted your phone. If not, root it first, and then use TitaniumBackup or something similar to backup your apps and data.
Download the ClockWork recovery from aosp's twitter page, be sure it's the one for the OV. If you downloaded via your PC, hook up your phone via USB and transfer it to your sdcard.
(you might as well put your custom ROM on there now as well)
If you don't already have it, download the terminal app from the android market. Once install, open it and type: su and press enter. You should get a # sign prompt, if you still have a $ sign prompt you are not rooted properly, get root and then continue.
At the # prompt, type: flash_image recovery /sdcard/THE-NAME-OF-RECOVERY-FILE and press enter
Once it has finished successfully, type: reboot recovery and press enter, this will take you straight into your new recovery. Another way to enter recovery is to hold the home+vol_down+power buttons all at the same time for a few seconds. Once in recovery the first thing you should do is backup which is called making a nandroid backup, you can then wipe caches, format partitions, and then install from zip your new ROM.
