Root clockworkmod installation error please advise/help
adz63
ok so i just updated my oxygen 2.0 rc6 to rc7.. i then went to install a theme via amon recovery 2.0 and this is what it said when trying to update
install from sdcard
finding update package
opening update package
verifying update package
E:Missing file
system/framework/services.jar
E: verification failed
installation aborted
ok i then looked on the post and saw that i had to use clockworkmod 3 or higher so i put it onto my phone via fastboot
when trying to put the theme on now it says this
finding
opening
installing
amend scripting (update-script) is no longer supported
amend scripting was deprecated by google in android 1.5 .
it was necessary to remove it when upgrading to the clockworkmod 3.0 gingerbread based recovery ..
please switch to edify scripting (updater script and update-binary ) to create working update zip packages
is there anyway to fix this ........
if not am i able to flash the theme the same way i did to put put clockwork on
ie adb fastboot bootloader
fastboot flash (whatever needs to go here instead of recovery ) frost_desire_02_rc7.zip
amonRa would have worked just fine
you just needed to go to advanced and toggled signature verification
enabled says sig verification failed and disabled it says about the amend script etc
it says that on amonRA or 3.0.0.x? i thought you flashed clockworkmod?
3.0.0 does not support amend scripts, theyve gone down the avenue of forcing new scripting methods from google even though most people dont use them yet hense the error
eitherway if the script requires 3 then i would sack it off. clockworkmod 3 for desire is unstable and other roms and scripts are not all compatible as they do still support ammend scripts
flash amonRA back (2.0.1 is better) then toggle signiture verification
ok i re-flashed amon turned verification off and it installed but has been stuck on splash screen since about 2 mins after last post
