OK.You need to install gapps yourself.
This is the ROM I'm using because I only use this phone on WI-FI so I basically don't need the other fixes lol. But I wanted to play a game which requires me to tilt the screen but it doesn't work. Is that problem from the ROM or the hardware of the phone?
Nope. Apparently I broke the sensors too. Added to my todo list.
Hmm, never tried any headphones with inline volume. I'll have to check the libaudio source to see if I'm missing something.
Its still there by developer Christ Kober. I would try the free version then commit for paid app if it works well.I think there was an app in the play store for headset buttons
I saw a very old thread CM 7.2 by Boraichee. It seems that mms data never got completed on that version. It could be something with the xml files.
Any Progress?
What's the word on this? I'm on stock rooted 2.3.6 and I'm at my wit's end. I really need a custom rom, and I'm really hoping its cm7. Barring that, can anyone recommend a different rom until cm7 is working?
O.A. is my daily driver. Has been for a while now. Works great, and accepts pressy's 1200mhz oc kernel. CTMod is another good one, and likes the oc kernels. Version 3.75 was the last completely working version, although 3.80 only has minor bugs. Last I checked they were being worked on. Now that I mention it, I will have to check that thread.
OA is fantastic, except for a little problem that I'm having. Maybe you can help?
I flashed OA EXT4 with OC (works beautifully), and flashed the accompanied metro fix. However, even after apn restores and reboots, it insists I'm on Cricket. If you or anyone else could help, I would greatly appreciate it.
Sorry for going off-topic.
When I had my Admire, I was on nTelos. Every ROM I used had to be modified to use the nTelos APNs, but it would still show Cricket/Metro on the notification window. If you want to change it, you can make the necessary adjustments to the build.prop
What is the setting in build.prop? I can't seem to find anything that pertains to carrier or anything. I need my data fixed soon =/.
So, how's that cm7 going? =D.
