Root CM10 Battery life.
I have CM10 and this is what happens to my battery. Anyway to fix this?
I see the problem.
On the left, look at the very first peak. Look to the right a little. See how its cut off and suddenly drops?
I see the problem.
He ran a hardware-intensive app, watched a video, etc? With the amount of time showed in this graph, that drop was probably around 10-30 minutes. The graph is showing over a day.
I dunno, this doesn't happen to me, that I have noticed anyway. My battery lasts 2-3 days idle. I will check my battery stats in a few hours, and if I don't get anything, then again tomorrow, see if I get any drops like that.
Did you ever calibrate your battery stats? I don't know if the rule still applies on newer phones but you usually calibrate your battery stats after installing a new ROM on it. The Android technology never shows a "true" percentage of battery power to prevent overcharging it.
Calibrating your battery is a myth :p
Its tru calibration is best new or old but not just the calibration is good its charging and killing that following it.but when you calibrate a battery try to do a fix permission in the clockworkmod ...
He was saying that constantly charging and unpluging your phone when it is not needed nukes your battery.
Just roll with the battery drain, bro. I called this out when we had the first alpha, we are still in the development phase and bugs do need to be ironed out. If you cannot live with it then switch back over to 4.0.4, at least you know that is stable.
(Edit) Permission reset? Why the f**k would that be needed for battery calibration?
It's supposed to only run with d, but can run with c when modded right. I'm running mine from c and then flashing cm10... I don't know what the hell I did and I've been trying to replicate it.
