all fixes including front video
allfixescm10bobz.zip
yea i didnt post it on the page of fixes yet cuz i'm lazy
im working on aboatrights jellybam but i'm getting fc on settings at the moment
Is their a fix for bluetooth?
Connecting to a Bluetooth car stereo is what their referring to I believe because Bluetooth earpiece works for me
ahhh, ok, not sure on that one lol
I replied to you in my cm10 thread to if you'll take a look.![]()
) but on BobZ 5-21, Bluetooth isn't working past establishing connection. You can connect to a device just fine, and then nothing, no transfer of audio or data in either direction.Not sure about PG's build, because I don't use it (no offense) but on BobZ 5-21, Bluetooth isn't working past establishing connection. You can connect to a device just fine, and then nothing, no transfer of audio or data in either direction.
PG: Which files specifically deal with an ongoing BT connection? Do you know? Once johnny said that his BT headset was working on your build, I tried swapping out every single BT related system file from your build to my phone, and got nowhere. Any ideas on how I might get it working? Or where to look?
And here's the front video fix..
http://androidforums.com/motion-4g-all-things-root/753220-bobz-5-21-front-video-fix.html
well the front facing works on pg's....thanks for the file tho will keep it for later use..
