Root CM12.1 Unofficial Beta
Any idea what the star in my status bar means? No idea what I activated lol!
Sorry for double post but couldn't add it with edit...
EDITED: Installed the latest build got it to work and everything is smooth sailing well not the rear camera but other than that keep up the good work! (glad to have vibration back)
Does anyone know how to fix the deep sleep I have tried the apk many times and it doesn't work for me or do i have to wait until there is a stable version or until they fix it? I am on virgin mobile lg volt
it means that your phone is in "downtime mode". basically its quiet time from the previous CMs. its under sound > interruptions > "when notifications arrive". setting it to "always interrupt" disables it. alternatively you could just push a Vol button and pick "all"
Thanks! I see it in my volume bar now. I must have had fat fingers yesterday.
Everything works perfect, except charging seems to take far too long, no matter power source. Any fix/suggestions for this?
First time I have ever had to ask for help installing a ROM. I rooted the phone (Boost version), installed the 2.8.5.0 TWRP, then used that to install the ROM in the first post. Wiped caches and rebooted.
All I get is the blue android head logo. I waited 20+ minutes and then used TWRP to restore my backup, which works fine.
Did I somehow miss a step? It does seem to install fairly quickly for a 200MB system image (probably around 10-15 seconds).
do a factory reset and it should work.
Think you should wipe
System
Data
Caches
Internal storage
Then flash, reboot
Kinda want to give this a try, but a little skeptical without a clear list of Working/Not Working. Did I miss that somewhere in the 30-some odd pages?
I have a older build, Only a few things are buggy/missing for me. I had to install setCPU and SuperSU to fix the deep sleep problem which is mostly gone(only happens once every few days) and I had to install the APN Fix for Boost and APN Change to fix the null APN problem too. Also NFC is borked. I have idea what works with the latest build, Common issues are Camera/APN(LTE not working) and Vibration not working/missing. I think Deep sleep got fixed with the last update tho.
What happen to the LED menu? I don't really want the charging LED on but I can't find where the settings menu is and I tried searching the root for the config file and i'm getting nothing. Also xled won't change anything in xposed. This is all on the latest build (3/26).
I like the ROM, thanks, Bad_MOFO_33! Switched from 3/16 to 3/26 build and experienced performance regression until I set SELinux to 'permissive' (*attached SELinuxModeChanger .apk) and changed I/O in CM12 Performance settings from 'row' to 'deadline' (w/set on boot enabled). So, I don't know which of the two was bogging it down before, but I can say it seems to perform well like 3/16 after permissive and deadline changes. No deep-sleep issues so far. Good job! :)
