Root Cm6 does not work with unrevoked.
[Program] SimpleRoot OTA 1.47.651.1 Edition - xda-developers.
Follow these directions. It will work if you did that update from sprint around July 4th. Then after this step do this:
How to start over: Fully rooted stock 1.47.651.1 in one shot (no adb!) - xda-developers
You will then have full Root with NAND
Lol tried that one also. Got to step 3. It tells me to load http://bit.ly/something something and i do then it tells me to reload the page and nothing happens. I have tried reloading it a million times, on wifi, not on wifi. I have started over a million times and i keep getting stuck at step 3.. Idk what to do.
What does your screen on phone do when u load that page? Do you see a smal image at the top and then hear a Knock Knock. from the image on the phone.
ill try to redo it right now and tell you what it says. I know when i reload the page i see a little red picture then some balloons then something else.. will check back when i get to that step.
He says he can not get past Step 3, you know after you type in your browser you get the balloons and then black screen on the computer will tell you to go to step 4. (He is not getting that) I say go to step 4, like i did.
Just do Simple Root I had OTA update and it worked for me.
I know what hes saying I was refering to the 3 step Simple Root that does not require any typing.
Badabing badaboom!! It worked!
Yep! Full nand unlocked! My HBOOT now says 76.2 which is full unlocked when before it was 79 which is part nand unlock. Thanks everyone for the help.
