CM6 LP plus instead of ADW
chawski
I wanted to switch to LP plus for my homescreen on CM6. how would i go about deleting adw? is it necessary to even do so, or is adw small enough its not going to matter having both installed?
I would not worry about deleting ADW, pretty small
I replaced ADW with LP+ & when I checked my battery, (was draining fast) I saw ADW was running. Only about 2% of battery was being used but that was enough for me to delete it. I used Titanium Backup to get rid of it. I'd say check your apps (I checked mine with Switchpro) & if it's running get rid of it.
