Root CM7 amd Wireless Tethering
I can't seem to get the wireless tethering working with CM7. At first I was using the wireless tethering app but then I read that CM7 has built-in wireless tethering. So I went to the wireless settings and tried to activate the the hotspot feature, it just says "error".
Does anyone have any suggestions?
try wiping dalvik cache and cache.
Did you uninstall the wireless tether app before using the native wireless tether? After you do that, then boot to recovery, wipe cache and dalvik cache and then reflash the CM7 build that you're on.
