it doesn't really matter what carrier u have on your tu. All it is is a different prl. That's all.
But I am on a sprint phone for your future refernce.
Somebody wanna help jdogrambo fix 3g and wifi....I'm a little busy compiling Ice Cream Sandwichcan't wait till wifi and 3g work
Sure I will help. What do you need?
Please test and verify all fixes for CM7. This will really help to make this project go faster. If new apps are added, then please test them to make sure all the functions of the new app work in CM7. Thanks for all the posts so far....they are very helpful.
Edit: The first release of separate Boost and Sprint CM7 zips will have stock files added but might not fix anything. The files I'm adding are necessary for hardware to work but the nuts and bolts of making that hardware work takes time to figure out. They are the files that init.rc needs to initialize hardware.
when will the boost one be released do you know?
ui_print("");
ui_print("Verifying device");
assert(getprop("ro.product.brand") == "samsung" || getprop("ro.build.id") == "GINGERBREAD" || getprop("ro.product.name") == "SPH-M930BST");
ui_print("Passed");
Wifi failed is caused by something in/with the driver according to the logcat
