loganmedwards
I'm installing CM7 right now, when I try to install CM7 from sd card it keeps aborting the installation. What do i do?
phone rooted already I'm guessing, clockworkmod installed and what version?I'm installing CM7 right now, when I try to install CM7 from sd card it keeps aborting the installation. What do i do?
3.0.0.5
I ran 3.0.2.4 and have flashed back and forth from CM6 to CM7 about 10 times now...lol...Should I reboot and start over?
Go here for the guide on how to install. Very easy steps.
http://androidforums.com/ascend-all-things-root/309499-how-install-cm6-7-comprehensive.html
try following this:I am running into a big issue. when I get to the "copy gapps and cm7 .zips to sd card" step, I open the file manager and see "CD Drive F: Huawei Ascend M860" drive there. But this drive is read only, showing the following folders:
document
res
us_driver
autorun.inf
and some other files.
Windows shows that this drive is only 11.8MB
I can't copy CM7 zip file on this drive.
Help
