Root Cm7 no market
i flashed cm7 by self for the first time (without rom manager) and now i have no market nooooo lol please help
You need to go to the CM site and look in the wiki. There is a Gapps file that you need to download and flash. It has all the Google Apps that normally come on the phone.
Great Thanks man just a couple sd card files... Flashed a sense rom to get good GPS and voicemail and the whole rom seems to be taking up a lot more space...
yeah stuff on your sd card is fine to delete. if an apps needs a file it will create one if is not there. so yeah go for it. i hate how some roms add their extras on files on my sd card. every now and then i have to do some spring cleaning on my card and delete those stupid files.
Yeahh I know man exactly my problem lol I flashed a whole ish load of roms for a little bit was on cm7 but GPS wasn't accurate at all always like 3 streets away... Voicemail was weird too but I guess I'm too used to visual haha I swore only aosp roms but I really think I am stuck on MikG sensne 2.1 + 3.0 the whole thing is really fast almost matches cm7 and the GPS is so accurate and not a lot of extra runnin backround stuff like a aosp rom. Am I gonna have to look one by one and delete all these bs files?
I noticed all the sprint apps are there in folders like fresh removed apks and someone else removed apks and they're all sprint apps... I do not intend on ever using them but if I ever need to go will the backup be enough? Or keep em all?
i would just delete them. unless you think you would want them later then keep them on your computer. but you can definitely delete them from your card.
