Root cm7 random problems..
badhabits727
Last night I flashed the current cm7 as well as gapps, tiamat SBC, and dt a2sd. Have a2sd set to move dalvic and data to SD.
Now for my problems...
"Waiting for GPS" enough said.
Pressing power button to wake to lock screen takes a few seconds before I see my lockscreen, sometimes I have to hit it a second time to get my screen on. Never had this problem with any other rom.
try this:GPS Fix
also have you tried and wiped dalvik cache and cache? is your card partitioned? did you wipe sd ext before flashing cm7?
Tried wiping cache and dalvic. Yes card is partitioned. It was freshly partitioned for the first time when I installed cm7.
And I don't quite understand how to do the GPS fix.. I have to use Tom manager? I've had nothing but bad Puck with it in the past and deleted it already.. also, it says restore to something I've never ran to make a backup of?
