Root CM7 SSX or Justice?
Sarnow
I am going to try one but not sure which is better as far as bugs and function. I thought I would get some opinions.
1. I use my gps daily so I need that to work.
2. I use my camera quite often also.
3. I also need fairly good battery life as I don't usually have a chance to charge it during the day.
they all have short battery life
cm7 was the first and has nightlies and has fixes that you must install separately
ssx is fast, and snappy, everything works, maybe even the gps, camcorder i think works or has some bugs
justice, have not tried so not sure about it.
I treid SSX, and it was working really well. You do have to apply patches for the camera/camcorder and 1% battery......well at least you did on the first release, I don't know if any updates have been released or not.
I would pick CM7 only because it's the base of all the other Roms you mentioned and has actual nightly updates to fix potential and known problems. Just my .02 cents though. When I go back from Gingerbread, this will be the ROM I personally pick as I was very happy with it short of a few problems like currently poor battery life, no HD camera and no HDMI out. Otherwise it is incredibly snappy and fast, again being back on Gingerbread, I miss it in this regard.
Here's an idea. Why not just use the leaked pre rooted .596. Pick a theme you like. If you want more speed then overclock. You get everything working and good battery life.
