Root cm7 video recorder issue...
RunVert
running cm7. Not sure if this is a ROM issue or not. But in video recorder settings I have 4 options:
High (30m)
Low (30m)
MMS (Low, 30's)
youtube (high, 15m)
...If I select anything but the "low" options, my video recorder forces close. The "low" options I can record but the video quality is blurry and no-where close to clear.
Anyway of being able to select the "high" video settings in cm7?
PS--I tried rebooting and it didnt fix it.
i just checked mine and i can record in high settings with no issues. you may want to try wiping cache and dalvik cache and see if that helps.
