Root CM9 device files
dsmryder
Android Expert
Our device section got mirrored to the vendor section. I don't know how it happend, but the device files are gone. If someone has the project on their computer and hasn't sync'ed in the last couple of days, could you forward me the files so I don't have to remake the whole thing?
Rukin was able to help me, but his files were 3months old. If someone has something newer, that woud be helpful.
You mean the vendor files got pushed to our device files? Check my github, I just pushed the most recent device files for MTCM9. Once I get this kernel done I'll update all the include files. These should be up to date, I think I grabbed it some time this month.
Thank you thank you thank you!
OK I'll mess with it tonite.
Don't you use a version control system? you should be able to roll back to previous commits... (I know GIT does this, possibly SVN too)
That's one of the wierd things. The .git folders are for vendor. If you look at the history of device you would see the last change was a few days ago. If you go into the project you would see the last change was like 3 months ago. I emailed github, but they haven't responded,
