Root com toast errors and all calendar events disappear!?
dan55
Android Expert
hi guys.
had this a few times now recently.
I get a few toast messages saying that various .com process
have forced closed,including google service, and then all my
calendar events are gone! :-\
reboot needed to fix.
anyone else had this? I'm using dGB11. bad install maybe?
as not had it before on dGB
thanks
dan
I'm fairly sure the last 2 times it has happened were shortly after I switched to wifi.
didn't need a reboot to recover this time, just went into the calendar app
cheers
might be this?
Looks like PI is leaking a service:
E/ActivityThread( 2197): Activity net.webis.pocketinformant.MainActivity has leaked ServiceConnection net.webis.pocketinformant.MainActivity$1 @40577d80 that was originally bound here E/ActivityThread( 2197): android.app.ServiceConnectionLeaked: Activity net.webis.pocketinformant.MainActivity has leaked ServiceConnection net.webis.pocketinformant.MainActivity$1 @40577d80 that was originally bound here E/Acti
happened just now. no events in PI and
stock calendar crashed
He says he only has issues on dGB. But the error points to the pocket informant app. Possible compatability?
hmmm where did he pull that error from? is that some kind of log?
only reason i ask is that is it possible PI does that anyway and the google calendar issue isnt actually related?
what happens if he freezes pocket informant for a while and sees if the issue remains?
cant see how it could be a compatibility issue with a stock android build and its not even consistent
hi guys.
yes good point. the PI error might not be related.
will try going back to mild wild and test it for a week.
had the missing events issue again today but this time no
pop up error like above
cheers
back on MW now - 2.5 i think - nandroided it up - my first time :) all seems to have installed ok - will monitor the calendar/com issues
oh dear - just had my first com error using mw 3.5 ox :/ bummer - had just added new event in business calendar and then refreshed Agenda widget...and bang! error msg and missing widget events
still getting these - ive removed my normal cal apps - but stil get framework error - pattern seems to be: on wifi and remove and event - a bit later get framework error and all events disappear - have to reboot to recover them
different roms too - so could it be asop s/w bug?
really? ;) well yes im thinking it is that - but it is tracking down where the bug is that is my pain now - then i get get on to the app devs about it ....unless it is in the rom itself :/
have i sunk that low already :D that is a desperate move for sure - im not sure i can go that far ;) ive remove some of my cal apps to see if that helps
